When I first learned how to solder I was told solder is for electrical connection only, not for mechanical support. But many things do not follow this and seem to work ok, so I'm not really sure what the correct answer is.
The no nut mounting method is actually quite elegant, one advantage is you could use pots with different shaft lengths, you simply offset them on the pcb whereas on the panel everything lines up.
