jensenmann
another passive eq?
« Reply #20 on: March 31, 2005, 12:09:13 PM »
yes, that´s true. And they make nice mikes, too. :wink:
Jens
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
Re: another passive eq?
« Reply #21 on: July 20, 2006, 09:11:25 PM »
Quote from: "synthi"
I`ve got a couple of RFT Kleinstudiogerat mixers and finally I`ve found the schemos for them.
The eq section seems to be passive, so the schemo would be interesting:
I`ve got 4 of theese eqs, they are thinking to be inserted in the preamps, the bad thing is that you can only use the "prasenz" presence or "hohen" trebble one at time since they share the switch, Do you think they can be moded for using separate controls at time? algo there is a easy way for having "Q"?
Synthi.
hi!
i got exactly those FE 625.31 filters, can anyone help me with Pin in/out connections, please? I`m too bad in readin shematics. I would appreciate it much!
thanks in advance again.
ciao
chester :thumb:
another passive eq?
« Reply #22 on: July 21, 2006, 12:34:13 PM »
noone ?  :roll:
ciao
ioaudio
another passive eq?
« Reply #23 on: July 21, 2006, 06:50:55 PM »
what exactly do you want to know?
another passive eq?
« Reply #24 on: July 22, 2006, 06:56:47 AM »
hi!
i want to know wheres the Voltage is correctly come in and wheres the  Input of  the audio and the output of the audio :sad:
Is Pin 1 = 24V and Pin 5 = Ground ?
How do i get the signal in and signal out?
ciao&thanks
ioaudio
another passive eq?
« Reply #25 on: July 22, 2006, 07:37:57 AM »
Quote from: "chester"
yes, thats right.
you can find the in&output on the small socket KL1.
4 = input and 2 = output
another passive eq?
« Reply #26 on: July 22, 2006, 12:11:42 PM »
thanks! will try that out!
ciao
chester
headcleaner
another passive eq?
« Reply #27 on: August 15, 2006, 03:08:01 AM »
hello,
tanx a lot for this thread & for all the schemos. we should talk more about the GDR-stuff, its kind of simple and pretty good sounding...
and i´m thinking about cloning this eq, with new transistors, the inductor will be self made...
but i can´t  read the values of c10, c11 & c12 - any ideas.
and i don´t really understand switch s3. are all 6 caps in one dimension of the switch?
cheers
opacheco
« Reply #28 on: June 17, 2019, 02:09:13 AM »
Do somebody have information about the VEB FUNKWERK LEIPZIP MV 4056??
I have one unit and I would like if this mic preamp is so good or I wouldn’t lost my time in that!
I love the Vaccum Tubes Sound!!!
volker
« Reply #29 on: June 17, 2019, 02:52:06 AM »
I have two of these, sitting in a box for years... For microphone preamp use you would need at least an input transformer. But as you probably know yourself, these things are tiny, absolutely no way you will get one in there. Super simple circuit, what exactly is your plan?
opacheco
« Reply #30 on: June 27, 2019, 12:19:12 AM »
Volker,
Thanks for your comments!
I want to modd for mic preamp.
What Input and Output transformers do you recommend to me for?
Opacheco.
opacheco
« Reply #31 on: July 27, 2019, 07:23:37 PM »
Volker,
Opacheco.
Any Idea?
Opacheco
Last post September 17, 2004, 05:33:53 PM
by NewYorkDave
Last post October 31, 2004, 07:54:49 PM
by Marik
Last post July 13, 2016, 01:07:20 PM
by mjrippe
Last post July 14, 2005, 03:40:26 AM
by gyraf
