[quote author="Adky"]Any Suggestion on Upgrade and Mod on the NADY TCM1050??
It has a Solder on 12au7 or At7 [/b][/quote]
Yeah, this cruel habit to solder tubes...
Adky, you have an earlier version of this Nady. The later ones use sockets and different hardware, in addition to about 10mm longer body.
I have modified both of those, and they have same schematics. I 'reversed' it, but cannot find where I put it, maybe Gus has it.
Here what I did. First of all, unsolder the tube and put a socket. The regular one won't work here. I used pins--contact Kevin Carter--he has them, and will understand what do you mean. I changed the tube for 6072 GE 5 star. The input stage of the shematics is a C24 clone (one half)directly coupled to CF, with unusually high value of cathode resistor in CF--278K. They did it because the value of resistor that high, raised the impedance of the tube, and at the same time lowered the bias, and thus they could use cheap off shelf 1:10 output transformer. I changed the trafo for LL1550, connected as 1:4, and lowered the value of cathode resistor to 72K. I used Caddock resistors. In the place of bypass electro cap use Black Gate. Also, you can try experimenting without it, at all and see if you like the sound. In addition, I removed inernal screens of the grill, leaving only outside, thicker mesh. After these mods the mic sounded very good.
Let's hope Gus will chime in later--he did something different.
