LA2A style chassis are SOLD OUT as well now!
I'm preparing a new batch but it will take about 6 weeks until it's ready for shipping.
Also for the LA2A style chassis I'm thinking about doing a new revision - even closer to the vintage chassis.
That would mean:
- new back chassis consisting of two parts instead of one. The one part being the bottom & back panel and the other part being top & side panels. That would probably cost a little more to manufacture, but it would be much easier to work on and to wire it all up
- new custom hinges that look exactly like the ones used in the vintage units and are built like a tank.
- new cutout where the vintage units had a can cap mounted to the back panel. A blanking plate would be included so you could choose wether to use a vintage style can cap, or modern electrolytics.
Basically the only thing pointing towards a modern build would be the IEC socket on the back.
In the meantime if you need an LA2A style chassis NOW, Don-Audio.com still has a few of my current revision LA2A style chassis kits in stock - at a slightly higher price than here though...
I'd like to hear your opinions on my above mentioned thoughts regarding a new - more vintage looking, and easier to work on revision of LA2A style chassis
Martin
