Martin,On the CE metal can caps, did you use insulators in addition to the metal mounting plates? I can't really tell from the chassis pics. Thanks.
Finally getting around to these...Where did you find the 0.17uf caps? Mouser doesn't have them. I've also searched 170000pf and 17nf. Thanks!
BTW, what gauge wire did you guys use on the filter unit that will allow 36 conductors to fit through the hole in the filter box and chassis? Is 26 gauge too big?
Hey Robert,actually all these Switchcraft Telever (16000 series) switches can be made latching.I was wondering the same thing too back then.They are all momentary, but there's a small metal plate on these switches - held by a screw. remove it and it will be latching
