RuudNL said:I am sure the corrected circuit diagram works a lot better than the previous one! ;D
You can tailor the LF response by changing the value of C5, to adjust the LF roll-off frequency.
ln76d said:Below is simplified version, without pad and hpf, if someone would like to use it with schoeps circuit PCB or build it with perfboard, It's a less parts.
Really good results are with double bipolar 10uF in parallel for C8.
I've been waiting almost 8 years for @Gus to answer these questions, haha.Why is better?
What's 2?
