Harpo
Re: [BUILD] New FET/RACK Official Help Thread - Please read first post!
« Reply #1720 on: September 03, 2019, 03:27:06 PM »
Q12: C= 26.23 ; B= -9.14 ; E= -1.59
doesn't look to be working correctly...
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
YoDudeRock
« Reply #1721 on: September 16, 2019, 11:19:57 AM »
Hi Mike (and friends),
      I am having a weird problem with a Rev A.   It was operating perfectly normal for about a month...
now the VU needle has started meandering around from zero  (above and below).
There's no noticeable audible effect, although it's probably subtly affecting the compression.
I did some checking with my multi-meter and found voltages in every component in the GR Control Amp
section meandering around too.
For instance on Q10, the Collector is a rock solid: 30.78, but the Base and Emitter are fluctuating from 13-17v DC.
Pretty much everything below that in the GR Control Amp section is fluctuating by about the same ratios too.
What would be the most probable cause?    Loose connection?  Bad capacitor, transistor, resistor?
I've changed both Q1 and Q11 (had a spare matched set), Q10, R49, R50 and C18.
I've also re-heated some solder joints too (R50 particularly), which has greatly reduced the amount that the VU meter is moving, but it's still "moving" back and forth a little bit.
Any ideas?
Any help is much appreciated,
Chris Trentham
Hairball Audio
« Reply #1722 on: September 16, 2019, 01:58:18 PM »
Could really be  any of those.  I'd suspect a leaky cap or damaged semiconductor in that section.  Also, look for uncleaned flux.
Mike
Hairball Audio, LLC
DIY Parts and Kits
https://hairballaudio.com
Top secret stuff and upcoming releases:
http://instagram.com/Hairballaudio
http://facebook.com/hairballaudio
YoDudeRock
« Reply #1723 on: September 18, 2019, 08:30:27 AM »
Mike,
    Thanks so much.   Just wanted to follow up.    I finally, reluctantly replaced the rest of the 2n3707's at Q9, Q8 and Q7.    And success!   Voltages are all rock solid now and the same with the VU.   Before, voltages in the GR Control Amp section were meandering all over the place like a stock ticker during the trading day.   :D   It was obviously one of those 2n3707's causing voltages to fluctuate in that manner.     Hopefully this helps someone else in the future.  :)
Thanks again,
Chris Trentham
Hairball Audio
« Reply #1724 on: September 18, 2019, 03:45:00 PM »
Mike,
Thanks again,
Chris Trentham
Nice!
Hairball Audio, LLC
DIY Parts and Kits
YoDudeRock
« Reply #1725 on: September 24, 2019, 03:22:20 PM »
Mike (and friends)  :)
    I am working on two Rev A's and I ordered the matched 2n5457's and two stereo link cards.
Question...Is it important that the hFE of Q12 and Q13 in both units (all 4 transistors) be matched as closely as possible?
Is there any advantage to matching all four transistors to the same value?
The reason I ask is, right now I don't have 4 that match, I have 3 at 405 hFE and 3 others at 410 hFE (and various others).
Also, any other tips to "matching" units?    The guy I'm making these for says he wants them "matched as closely as possible".
Chris
Hairball Audio
« Reply #1726 on: September 24, 2019, 03:24:27 PM »
Chris
Q12 and Q13 being matched just allows you to calibrate the comparator meter circuit on the individual unit.  Don't worry about matching those.
Mike
Hairball Audio, LLC
DIY Parts and Kits
YoDudeRock
« Reply #1727 on: September 27, 2019, 07:26:26 PM »
Mike,
     I'm testing my 2 Rev A's with Active Link cards.   I noticed there is a little bleed from one unit to the other, when Linked.  If I only send a signal only to unit 1, I'll still see about -50db coming from Unit 2 on the other side (in my DAW, Reaper) and vice versa.   Is this normal?  I assume it is since this is living, breathing analog.    I tried recording it and it's basically inaudible.
This is for a customer of mine, so I didn't want to send it to them if this isn't normal.
Chris Trentham
« Reply #1728 on: September 28, 2019, 03:18:19 AM »
Hello everybody,
I've just completed the assembly of  a Rev A kit I bought about a year ago (it's a 2017 v1.14 pcb) . I have +29.7vdc and - 9.44vdc at the power rails.
During the q bias I was getting only 0.132vac at output. I started going through the troubleshooting list and got  -1.337vdc to -0.776vdc at TP18 a little off but seems usable.
I measured 0.088vac at TP1 (little off), and then 0.017vac at TP15 (way off). I then grabbed my scope to try to figure out where the signal drop off occurs, and found it at the gate of Q1.
After reading the beginning of this thread I tried removing Q1 and the gain is vastly improved. I measure 3.63vac at TP15 and 16.45vac across output (ultra hot). I measured +12vdc at the gate of Q1 which also seems WAY off.
I've tried replacing Q1 and Q11 with spare 2n5457s I had with no improvement.
Let me know if you have any ideas of what to try next.
« Last Edit: September 28, 2019, 05:01:04 PM by More_Gain »
Hairball Audio
« Reply #1729 on: September 30, 2019, 03:25:33 PM »
Mike,
Chris Trentham
Probably, I've never tested it in that way.  It's a summing amp basically, it's not perfect but it's better than the stock link for sure.
Mike
Hairball Audio, LLC
DIY Parts and Kits
Hairball Audio
« Reply #1730 on: September 30, 2019, 03:32:03 PM »
Hello everybody,
Signal at the Gate of Q1?  There should be no signal there, just a negative DC bias voltage. Q1 isn't set up and a traditional transistor, more of a variable resistor to ground.
The 5457's particularity on the Rev A are very tightly spec'd.  Tossing any 2 in there, will probably not work out.  If you have +12VDC at the gate of Q1 that is your problem, not the FET.  You'll never pass signal with positive DC voltage there.
Do you have the CN2/CN3 heading in backwards or something? I check all your wired connectors for orientation.
Mike
Hairball Audio, LLC
DIY Parts and Kits
« Reply #1731 on: October 10, 2019, 09:59:20 PM »
Those GR amp outputs look fine to me.  I would definitely get proper FETs, I'm guessing you have knock-offs.
Mike
Well, tried a set of matched FETs I got from you and still the same distorted signal when the gain reduction is turned on. I also replaced all the 2N3707 transistors in the GR control amp section just to make sure that wasn't the issue. I once again checked all the resistors in the GR control amp section as well as all the resistors on the ratio pcb....everything is correct.  Need a new thought/direction to head in here because I am at a loss.
Hairball Audio
« Reply #1732 on: October 10, 2019, 10:10:33 PM »
So it works fine with no FET? Other than the lack of compression?
Hairball Audio, LLC
DIY Parts and Kits
« Reply #1733 on: October 10, 2019, 11:04:32 PM »
No, when I remove Q1 AND turn the attack on, I get the nasty distortion when 20:1 is selected. It's less of an issue with 12:1 until 4:1, which sounds almost normal. If I put the Q1 FET in and keep the attack off, audio sounds beautiful. If I remove Q1 and keep the attack off, the audio sounds beautiful.
« Last Edit: October 10, 2019, 11:09:01 PM by Deejsirois »
Hairball Audio
« Reply #1734 on: October 10, 2019, 11:09:49 PM »
No, when I remove Q1 AND turn the attack on, I get the nasty distortion. If I put the Q1 FET in and keep the attack off, audio sounds beautiful. If I remove Q1 and keep the attack off, the audio sounds beautiful.
That's nuts.  So nothing sounds good with the GR ON, FET in or out.  And you still cant get a voltage drop at your Qbias but you get a -1VDC to -1.7 (ish) reading at the gate?
Hairball Audio, LLC
DIY Parts and Kits
« Reply #1735 on: October 10, 2019, 11:14:54 PM »
Correct, nothing sounds good with GR ON. However, I can fully calibrate the unit...so we are at least good on that! Calibration went without a hitch, and I was so pumped thinking everything was golden....until I turned the GR on  >:(
Hairball Audio
« Reply #1736 on: October 10, 2019, 11:17:10 PM »
Oh ok.  So this is different than originally when you couldn't even calibrate the bias?
So everything calibrated normal, but in GR mode you have a lot of distortion?  Re-check your Pad 22/21/CR2 voltages under calibration.
Mike
Hairball Audio, LLC
DIY Parts and Kits
« Reply #1737 on: October 10, 2019, 11:30:50 PM »
Mike
Input: 12 O’Clock
Output: 12 O’Clock
Attack: GR ON (fully CW)
Release: Full CW
Ratio: Check All
Meter: GR
Signal: Sine 1kHz @ 0dBu (0.775 VAC across input + and -)
Pad 22                                          Pad 21                                                      CR2  Anode
20:1 =    0.460    VAC             20:1 = -5.80      VDC                       20:1=  -5.86  VDC
12:1 =    0.231                         12:1 =  -3.34                                         12:1=  -3.34
8:1 =      0.153                           8:1 =    -2.55                                           8:1=  -2.55
4:1 =       0.76.8                         4:1 =    -1.76                                           4:1 =  -1.76
« Last Edit: October 10, 2019, 11:35:36 PM by Deejsirois »
Hairball Audio
« Reply #1738 on: October 10, 2019, 11:32:35 PM »
Anode CR2?
Hairball Audio, LLC
DIY Parts and Kits
« Reply #1739 on: October 10, 2019, 11:36:10 PM »
