I was just about to pull the trigger on a stereo set and at the checkout I saw that there's no shipping to Europe at the moment. Damn you, Corona!!
Keep checking back. The issue is that we use USPS for international shipping and USPS uses commercial airlines to ship. With so many commercial flights cancelled, nothing is leaving the USA (other than to Canada).I'm trying to get a biz account going with FEDEX or DHL. Since they operate their own flights they are fine but they also tend to be much more expensive. Seeing what I can workout with them.Mike
I didn't open up the meter before I assembled everything, but should have to see what kind of bulb was in there. Does anyone know of a drop-in LED replacement bulb for these type meters?
Any update on the matter?
Yes. We're back shipping internationally using UPS.Mike
First build of a FET/Rack Rev A. No output at the xlr, no AC signal at TP15. TP 1 seems like it might be ok - it’s a little low (.090) but I’m not sure where the exact middle of the input knob is - so it might be ok. I’ve check all my solder joints and everything seems good.... Any more specific measurements I can take leading up to TP15 so I might see where the signal flow stops?
TP1 is fine.Check those DC transistor readings in the guide for Q2 and Q3. Make sure everything in the signal pre-amp box is well soldered, oriented, and the correct value.Mike
Q2 DC:G=4.76S=8.33D=14.63Q3 DC:E=14.01C=14.02B=14.67Q2 AC:G=.96 (same as TP 1)Q3 ACB=0C=0
Which leg is the emitter?
Weirdly, E on Q3 is 0 with the unit powered on, and it jumps all over the place with the unit off. It sorta spikes, then runs down from a high impedance number (in the 100’s) down to like .4, then starts high again.
Thank you for updating the doc. That’s awesome. Sorry for the delay, family responsibilities.The signal seems to die at “D” of Q2. It is .096 VAC on the other two legs. Zero after Q2. I have soldered and resoldered - wiggled it, etc, it doesn’t pass any signal to that pin from what I can tell.
.096 on the other two legs. 0 VAC on leg D.
