[BUILD] New FET/RACK Official Help Thread - Please read first post!
Hairball Audio said:
Not much to go wrong there.  Just those two resistors on the meter PCB.
- Get +4dBu (1.23VAC) signal across input output +/- and the meter should be at around 0  in +4.
- Get+8dBu (1.95VAC) signal  across input output +/- and the meter should be at around 0  in +8.
You can just use a 0dBu signal on the input like setting Qbias, then increase the output to get +4 and +8.  You'll need to be in GR off.  With GR on the signal will probably be too low.  That might be what you're seeing.
Mike
That was quick and easy.  Spot on again!
Thanks Mike.
Post back after you try that...I'll give you some other stuff to check.
Mike
Scrubbed with 99% isopropyl and a toothbrush, dried it with a cloth, repeated again twice. Issue is still going on. PCB looked pretty clean to begin with as I did this a couple times already.
Set your unit to:
Input: 12 O’Clock
Output: 12 O’Clock
Attack: GR ON (Full CW)
Release: Full CW
Ratio: 20:1
Meter: GR
Signal: Sine 1kHz @ 0dBu (0.775 VAC across input + and -)
Using chassis as your ground reference, what is your DC V at TP21 for all 4 ratio settings.
1. What are those readings?
2. Do they change as you rotate the release?
Mike
Set your unit to:
Input: 12 O’Clock
Output: 12 O’Clock
Release: Full CW
Ratio: 20:1
Meter: GR
Mike
4        -1.606
8        -2.435
12    -3.265
20    -5.9
No change in DC as I rotate.
On another note after a thorough warmup after the last cleaning the problem seems to have lessened. It used to swing from 0 to -7 or -10 and now it's only going down to about 0 to -1.
Going to clean again a couple more times and see if it makes a difference. Thank you for your time Mike! This is making me want to rescrub all my Lola and Gold preamps I built!
thecmarus said:
4        -1.606
8        -2.435
12    -3.265
20    -5.9
Those readings look good and it's good they are not changing with rotation.
Report back after a deep scrub....don't be afraid to soak the back side and let it run off the edge of the PCB. Get the ratio board too.
Mike
Mike
Mike,
Bought a gallon jug of isopropyl from my local hardware store and went buck wild on all the PCBs. Still getting the 1db drop on the VU meter when I put the release on 1, which is still better than my original problem which was from 0 to -7 or -10. A few things I've noted are that it is definitely worse until the unit has been on for over an hour or more. The VU meter takes a substantial amount of time to reach 0db, and I know this is normal for an 1176, but this is more dramatic than my Rev D kit.
Maybe if I'm feeling adventurous tonight I'll give it another scrub.
thecmarus said:
Mike,
You shouldn't have to scrub that much.
We need to figure out where the voltage is fluctuating to get to the root of it. I would have expected Pad 21, but no dice.
Scrub that attack/release PCB too!  Confirm all those values.
Mike
Hi everyone,
I've sent a mail to hairball but I thought I'd write here as well as Mike answers in this thread as well.
I've built two Rev D . nothing to report regarding the built, well documented, really top notch.
Seems my device is not even passing audio
On both of my FETs when calibrating Qbias, I get no AC reading on the output between OUT + and OUT -.
Also I understand that when the device is on OFF,, it should be in pass trough. Is that right? Because I also get no AC reading on the output between OUT + and OUT -. in OFF
I do get a reading on the output between OUT + and OUT - but only when i turn up and down the output control then it briefly reads between 0 VAC to 1.5 VAC or so but drops right ways to 0 VAC
To this question:
Set your unit to:
Input: 12 O’Clock
Output: 12 O’Clock
Attack: GR OFF
Release: Full CW
Ratio: 20:1
Meter: GR
Signal: Sine 1kHz @ 0dBu 0.775 VAC
With your DMM measure your AC at the following test points using the chassis as you reference (black probe).
-Input XLR + = FET1: 0.387 VAC / FET2 0.383 VAC
-TP1 = FET1: 0.110 VAC/ FET2 0.139 VAC
-TP15 = FET 1 0VAC / FET2 0VAC
-TP17 = FET 1 0VAC / FET2 0VAC
-Output Transformer BRN = Where is it?
-Output XLR + =  FET 1 0VAC / FET2 0VAC
The issue is consistent on both device, I need some heads up
Jec909 said:
Hi everyone,
To this question:
Set your unit to:
Input: 12 O’Clock
Output: 12 O’Clock
Attack: GR OFF
Release: Full CW
Ratio: 20:1
Meter: GR
Your signal is dying in your first amp stage. The signal pre amp.
Set your compressor controls:
Input: 12 O’Clock
Output: 12 O’Clock
Attack: GR OFF
Release: Full CW
Ratio: 20:1
Meter: GR
Signal: None
With your DMM measure DC at TP18 using the chassis as you reference (black probe). Rotate the Qbias pot (R59) and note the DCV at each extreme of the pot. What are those 2 reading?
Mike
Input: 12 O’Clock
Output: 12 O’Clock
Attack: GR OFF
Release: Full CW
Ratio: 20:1
Meter: GR
Signal: None
Mike
Thanks for the quick answer Mike
I get -00.3 mVDC with r59 full CCW and -2.97 VDC with r59 full CW
Set it to -2.97 VDC then try those readings in your first post again.
Lets just stick to unit 1 for now.
Mike
Mike
Sure!
With r59 at  -2.97 VDC full cw and 1000 Hz 0 dBu (0.775VDC)  signal to the input
-Input XLR +  = 0.383 VAC
-TP1 = 0.139 VAC
-TP15 = 0 VAC
-TP17 = 0 VAC
-Output XLR + =  0 VAC
Jec909 said:
Sure!
-TP1 = 0.139 VAC
-TP15 = 0 VAC
-TP17 = 0 VAC
Don't worry about BRN right now.
Your signal is dying in the Signal Preamp stage marked on the PCB.
Try removing you Q1 FET carefully and see if you get signal at TP15.
Mike
Mike
I unsoldered Q1 FET
And signal do not reach tp15
No VAC reading between chassis and 15
Jec909 said:
I unsoldered Q1 FET
You need to search through that Signal Preamp section marked on the PCB.  Triple check all component values, solder joints, and continuity. Something is a miss in there.
Check you transistor values against this chart in that section:
http://mnats.net/files/1176REVD_VOLTS.pdf
Make sure your power supply voltages are still good (+30VDC and -10VDC).
Mike
Mike
thanks mike. will do and report
Mike, feeling a bit confused.
On these test points, I should see DC or AC current?
I've been measuring  AC all the time :S
Depends on what your looking for.
In the first step we did (TP1, TP15) we're looking for actual audio signal, which is AC.  You input your signal (0dBu @ 1Khz) and trace that AC through the gain stages.  Your signal is measuring fine at TP1 which is after the T-Pad and input transformer and at the beginning of the signal preamp.
For a Revision D you should then see about 2 VAC (8 dBu) at the output of the signal pre amp which is TP15.
You have nothing there so your signal is dying in that signal preamp section. You have a wrongly paced component, damaged component, or bad solder joint/pad.  Measuring the DC V at the transistor leads as shown in that schematic with voltages, can help us narrow down the issue further.
Mike
I found the problem. I deserve a big slap . The issue was a missing resistor  LOL  :-[ (r8, which was hidden below the orange drop cap. )
I mostly wasted your time but I did learn a lot!  Many many thanks for your extremely valuable help and time.
