Thanks Guys
Khron said:
L5 - some "extra" RF-protection/filtering, most likely
Between ground only?
I know that inductor in ground path is for separation of grounds but not sure here
Khron said:
The common end of C7 & C9 seems to be some feedback node, judging by R25 coming straight from the output of that complementary stage. Not quite sure increasing C9 will yield any noticeable improvement - i see a 220k (R31) right after it, which would give a -3dB corner of 22Hz.
Today i made simulation.
I connected input voltge source in many ways since i don't know how exactly negative feedbck is applied.
In all cases increasing C9 value changed low end response significant.
I found that 100nF in parallel with 33nF should be what i need
Khron said:
Check my last post in technical documents
I don't want to make visible name and brand in google searching for some reasons ;D
Khron said:
And those two "paralellled" JFETs are, i assume, for manufacturing options? 2SK4041 seems to be some 4-pad "BGA"-ish package, and the 2SK3857 seems to be more like a SOT23.
I wouldn't be surprised if both are used.
One is for ECM type and another FOR IMPEDANCE CONVERTER OF ECM.
Unfortunately i can't verify that, because i have no acces to it.
All the parts around fets which have ** marking are mounted inside the capsule and there's no option to open it...
Gus said:
This is what i needed!
BTW. polarisation voltage is -70V not -60V.
Basic idea is to mod it a little, overall microphone sounds good but there's something unpleasant in it.
I can only exchange some parts from smd to tht.
Add mkp 100nF in parallel to the C9, change C15 for MKS , chnge C33 and C37 for silmic (if fit or any other good caps), remove C43 and C45 or replace it with fkp.
