Alternate transformers for MEQ-5
Quayhog
Bay Area California
The Triad HS-50 as used in the Pultec MEQ-5 is rare and expensive when found.  I've committed to one of Rainton's chassis kits.  Is there a consensus on an output transformer that will work as a similar and adequate replacement? I have some nice output transformers but would require a 3U chassis.  Would Altec/Peerless 15095 work?
I need to start my search soon.  The research goes on.  The 600:600 input should not be a problem.
You won't find a consensus.  26dBm headroom will be the hard part to find, the spec otherwise is very common.  The Edcors will do 26dBm +, though not a nickel core transformer.  The Altec won't do that level, but will the Pultec circuit?  Do the research on that part.
the 15095 is  also employed as an output transformer in the Altec 1567a.
the Edcor WSM 15k:600 performed very well for me.
the Pultec MEQ circuit cannot do over +20 dBm.
According to Sowter, their 1290 output transformer should also be a good replacement:
http://www.sowter.co.uk/specs/1290.html
It has a max output level of +24dbu
There must be some other options for the output transformers.  The rare HS-50 is probably way overkill in this circuit.  It exceeds all of the other components, from the tube era specifications that you might have in the signal chain.
The HS -50 is spec'd to 26dbm, the UTC A-24 as used in the LA-2a specs out at 15 dbm, this HA-133 at 22dbm,  the Altec 15095 with its mu metal can is at 15dbm.
The Triad B-6300 used in the Ampex recorder must spec as well as the the HA-133 since both were used in the same Ampex circuits.
I'm looking to find the specs for Bogen T-165.  It's a littler header to find specs and schematics that use it.  The ones I've seen use a 12AX7 or 6SN7 to drive the transformer.  The search for alternatives goes on.
I had opportunity to extensively compare two Drip Pultec builds that were identical except for transformers. One was all Sowter, the other has UTC A-20, UTC A-18 and new Cinemag S217D repro. I expected a lot more difference between the two units, but they were very very close in sound, THD and freq response. A lot of people would not be able to tell the difference in a blind test, including me. I dare say the Sowters have a vintage sound. Which is great news to me, now feel I don't always have to chase vintage iron and the associated prices to get good sounding, good performing transformers that can stand up to the iron of yesteryear. I am definitely more of a Sowter fan now from a sound standpoint.
So the Sowter 1290 Rainton suggested looks like a pretty good alternative to me.
I'm still waiting for the chassis.  To get the project going I will use the Altec 15095. I suspect that in a blind test it would indistinguishable from the original, all else being equal.  Using an octal socket wouldnt prohibit the use of an original HS-50.  The hole for the octal is about the same as the hole required for the Triad.
The next hard to source is RV4 spec 2.5K REVERSE Log/audio pot.  I have lots of useful DIY parts to trade for one or two.
