I have some questions.
When I go to other web sites I often find statements by "pros" that no reskinned capsule sounds like the "real" capsule. Some that come to mind are the brass versions of the CK12 and K87 and K89 capsules.
I can understand ones being done by SPA being different because of the changes.
I don't understand when the skin is the same thickness and same tuning frequency/ tension. PET is PET as far as I know.
I have a reskinned K67 that sounds fine it sounds like a k87 k67 capsule to me
If someone heat treats and tensions and uses the same materal and then graphs the capsule why do people say the "real" ones sound different. Capsules are not magic.
Is it the brass ck12 has not been made after about 1982
and the stuff in the world is stretched and "work treated" by being used??
this would not be the true new sound I would think.
Is it to keep a "magic" story thing going?
The older u87s I have been inside all seem to have a front skin with less tension sometimes the holes mark the backside of the PET. how can this be good.
My capsule was rebuilt by Doug Walker. Does anyone have microphones that have been rebuilt by say Korby or SPA that would like to share some information.
I can understand if someone that not rebuild the capsule correctly it not sounding good but some of the people rebuilding capsules must be doing close if not like what Neumann and AKG do/did.
I never saw an answer with science behind it why it does not sound right, just it sounds different.
