pucho812
What exactly is a mic calibrator and how does it work?
I asked the boys over at AP as I just started to use the acoustic measurement portion of the APX software.
I am trying to ascertain correct level of what the preamp on the measurement mic should be.
The recommended a mic calibrator? which I am not Familiar with. What does it do and how does it work?
I just need to make sure the DBX measurement mic and subsequent preamp we are using with it, is set to allow a proper level back into the AP. So far I got useable results in that it did register level enough to map things out but want to be sure I am at a correct nominal level.
Then what are the v/pa equations so I can covert that into dBu? I can't seem to find any direct information or online calculators.
Would love to learn more about this... If anyone has some suggestions as such.
