Creating a stereo version of an existing circuit
snaper
Hi Guys,
I really like the gentle compression / limiting of the optical things, like the LA.
After some research, I've built the LA-Light, as a fun little effect box.
Believe it or not, I love it.
I'd like to make a stereo version out of it.
The question is that if I want to turn it to stereo, is it "enough" to create two boards, match every possible components and use dual gang pots?
btw, here is the schemo.
As you can see, it starts with a balanced ot unbalanced converter, then the limiter.
I think I'll use a simple 1:1, 600:600 transformer at the end.
Could you recommend something "crispy"?
