could anyone explain how the Ratio control works, please?
Jakob wrote: "The sidechain signal that is obtained after the VCA is then full-wave rectified by two TL074-stages, and at this point an offset is added - and signal gain is controlled - by the ratio switch. The ratio switch actually changes the threshold a bit to compensate for level flukturations caused by different ratio settings."
i added the 1.5:1 Ratio mod to my builds (based on jwhmca's post in another thread), but i experience gain difference in 1.5 vs the other Ratios.
which resistors to change if i want to adjust it? and which are for the threshold control?
thanks
thanks
