Barklay
Re: [Build] CAPI BT50, 500 Series EQ (a la 550), Official Support Thread
« Reply #100 on: November 17, 2018, 12:15:56 PM »
Check continuity from each of the LF Grayhill wipers (the metal tabs that stick out of the switch body) to ground. You are looking for a short or very low Ω reading.
Ok, i’ve checked. Three of 8 were about 30 ohms. As Jeff posted earlier to Jan, i’ve de-soldered them and slightly bended, then re-soldered. After all, it works correctly
jona
« Reply #101 on: November 18, 2018, 06:43:04 AM »
Might be opamp related or cabling outside of the rack?
thanks  for the reply jeff..
i used red dots as for some of my other builds too.. i dont think it has to do with cabling.. i tried it in different slots and even in a different rack.. none of my other modules have this problem.do you have. any other  idea ? the strange thing is both bt50 have the exact same problem...
attisma
« Reply #102 on: November 26, 2018, 11:34:50 PM »
Hello Jeff,
I just built a pair of BT50's. I'm using known working gar2520's. My current issue is that when I run audio thru them, and with "IN" in either position, and all frequencies set to 0, I'm getting what sounds like a low cut filter.  If I boost/cut low LF, they seem to filter but I would expect the sound to be unchanged when positions are at 0.  Can you advise the best way to troubleshoot.
I've already spot checked and re-soldered my joints for good measure but to no avail.
Any help is appreciated.
jsteiger
« Reply #103 on: November 27, 2018, 07:34:27 PM »
Hello Jeff,
How are you testing them? What device is just before them? The BT50's input is unbalanced (like the vintage counterpart). Is it possible that whatever you are feeding them with does not like being unbalanced by shunting its XLR pin 3 signal to ground? Maybe try a quick test with a transformer output device before them.
Visit the CAPI store at http://www.capi-gear.com
CAPI is not affiliated with, endorsed by, or sponsored by API.
attisma
Re: [Build] CAPI BT50, 500 Series EQ (a la 550), Official Support Thread New
« Reply #104 on: November 28, 2018, 02:19:13 AM »
I was using a balanced cable. Problem solved!!
Thanks Jeff!!
« Last Edit: November 28, 2018, 03:04:01 AM by attisma »
