hitchhiker
I'm hoping to confirm that this amp which replaces the 900 EQ does in fact get hooked up to the
fader via the 18 pin connector? Also, does the input transformer feed this amp and then does this amp
next feed another buffer amp for the pan circuit?
https://groupdiy.com/index.php?topic=45864.msg783899#msg783899
Also, exactly which pins on the connector connect to the fader? I'd like to try this in my small
Sphere console which uses 10 pin connectors instead of 18 pin.
A sphere block diagram would be awesome, if anyone has one.
