Just got an Collins 26w that has a very thin sound
and it seems to loose it bass at the interstage trafo.
When feeding the input a testsignal I measure fullrange at the primary sides at the interstage trafo
but at the sec sides the bassrange is gone.
And if I feed the testsignal at the sec coils it measures fullrange at the output.
Desolder and measured the trafo with a ohmmeter
and both coils on the primary are opened
and the coils at the sec side measures 1.1k each.
Should it not be totally quiet if both coils are opened on the pri side?
At the moment it has a UTC(no info on it) as interstage, no idea if its original or not.
The Limiter has definitely been worked on but looks like proper work.
A lot of resistors etc changed around before the interstage
so it´s looks like its been problems there.
Does anyone have any info on the Interstage transformer?
Or recommandation for a replacement?
