Rompstomp89
Ive been pulling my hair out for a few weeks trying to troubleshoot some power supply hum in my Pultec Build. the hum starts when the tubes warm up and starts off loud and harsh (around 0db) and then fades to about -65db and just sits there. I had an idea thinking it was the main filter caps but replaced them and reflowed solder joints with no change. The hum fills the lower spectrum from 60-150hz.
Ive searched for hours on here and found some ideas. I tried shorting out the grids of the ax7 to see what happened to the hum. I found that shorting pin 2 got rid of the hum and just left a normal ground buzz then I tried pin 7 and the hum actually got louder and squealed a little. Ive changed tubes, checked solder joints, moved grounds around according to the layout (off of recproadio) I've grounded out the eq, input and interstage with no hum change. I checked resistance across my heaters and the most I could find was 0.4 ohms. I was thinking it could be a layout thing but looking at the original pultecs and my power transformer doesn't seem any closer to noise sensitive parts.
Im using Edcor input (all the way on the far side of the chassis from the PT right by the input jack)
Sowter output (outside of chassis by the output jack right next to the input jack)
Cinemag Interstage (mounted on back panel inside chassis between in and out jacks)
Heyboer PT 290-0-290 (center tap directly to star main ground. The heater center tap has been moved from the position in the layout to directly to star ground with no change)
LAYOUT:
http://www.recproaudio.com/diy_pro_audio/diy_files/eqp_1a/eqp-1a_layout_final.jpg
any insight would be amazing on this! the EQ sounds great other than this HUMMMMMMM.
thank you.
LAYOUT:
thank you.
