Whoops
Another Osciloscope Advise thread
« on: December 22, 2016, 07:44:40 PM »
I've been needing an osciloscope for quite sometime.
I bought one that would serve my needs but came non functioning,  there's some problems in the high tension part so I don't want to mess with it at least for now.
So my question is,
what's in your opinion is the "SM57" of Analog Osciloscopes?
I'm looking for something from the 80/90's, affordable, simple, from a good brand, nothing fancy but perfectly capable, that sold a lot of units at it's time so there will be more chances of buying one second hand and with widespread information and documentation in case it needs repair in the future.
2 channels, 5Mhz or more,  Vertical sensitivity at 5mV/div or better
johnheath
Re: Another Osciloscope Advise thread
« Reply #1 on: December 22, 2016, 10:50:11 PM »
Hi Whoops
I know I am not an expert since I just recently bought my own for the first time. I got many good advises about buying a used one to learn with and I suppose that could be a great idea… If I knew it would work properly.
So I I went for a new one.. https://www.elfa.se/sv/oscilloscope-analogue-2x30-mhz-gw-instek-gos-630fc/p/17618044?q=oscilloskop&filter_Category3=Oscilloskop&filter_Category4=Oscilloskop+analoga&page=2&origPos=3&origPageSize=50&simi=94.88
Since I, at least at the moment, only work with analog circuits I guess it will be just fine.
If you would like another one I could recommend this supplier: https://www.elfa.se/search?q=oscilloskop&filter_Category3=Oscilloskop
I know it is in swedish that might be hard to understand unless being a swede, but the company is located (or at least have their storage in Belgium I think) so they might have other languages available. They claim to be one of the largest supplier in northern europe :)  Hope it works out for you.
Best regards
/John
Nothing is impossible - It just takes some more time
Gene Pink
« Reply #2 on: December 22, 2016, 10:56:29 PM »
Not really a recommendation, the B+K 1479B 30 Mhz has served me well over the last 15+ years, and meets your spec's. Not many bells and whistles, but all the basics are there, including the very useful (to me) differential input function between two probes. Adds ch A + B, and invert ch B polarity for A - B.
Gene
Whoops
« Reply #3 on: December 22, 2016, 11:04:50 PM »
Thank you so much John, but I'm really looking for something that I can buy in the used market, and that might have a wider users knowledge base, and a well known brand.
Something like Philips, Tektronix, HP, Hitachi.
like the "SM57", or the "Marshall JCM900", "Fender stratocaster", or "Quad 405" for osciloscopes.
Hope there is a basic, standard model that a lot of people used and accepted at some point.
As I was a child in the 80/90's and only got into electronics in 2007 I don't really know the models from that period
« Last Edit: December 22, 2016, 11:57:58 PM by Whoops »
Whoops
« Reply #4 on: December 22, 2016, 11:17:03 PM »
I did a search for it, yes it definitely would fit my needs.
Actually the broken Osciloscope I have is the same as the B&K PRECISION  2160A. It seems that B&K PRECISION doens't manufacturer their own scopes they re-brand OEM products at least in the cheaper side of the product range. My scope for example is branded Univolt OS-3062 and it's the same unit as the B&K 2160A.
One thing I really didn't like was that the Service Documents were quite bad, confusing and lacking info. It's quite the opposite from any Tektronix or HP Service Documents that are really tight and complete.
Gene Pink
« Reply #5 on: December 23, 2016, 12:41:33 AM »
I wasn't aware of that, good to know, thanks. The only problem with mine so far, is dirty input range switches, one of these days I'll pull it apart and spray them.
That is so true,  15 years ago I emailed HP about a freq counter from the '40s, and got a huge and complete pdf. Back in the early '80's I called Tectronics on the phone for a 310(?) scope service manual, and got two micro fiches(!) in the mail. Luckily, a close friend that worked in a large office had access to a copier that printed micro fiche, he showed up with near a ream of paper that took him 5 hours to do. My initial comment: "You didn't print it double-sided?"  ;D
He almost took a swing at me.
Gene
Whoops
« Reply #6 on: December 23, 2016, 12:53:06 AM »
I compiled some info from web searches and reading.
I said from the 80/90's, it seems the time period would be more like from late 60's to early 90's
from the info I gathered this ones seem to be quite popular models, easy to service and with available Service documentarion:
TEKTRONIX
465
465B
465M
475
475A
2213
2215
2235A
HP
1740A
1741A
1745A
Hitachi
V-212
V-222
V-252
Philips
PM 3050
PM 3052
PM 3055
PM 3060
PM 3070
PM 3072
bremusound
« Reply #7 on: December 24, 2016, 03:14:37 PM »
My 35 yo HAMEG scope has never had or made any problems.
Brian Roth
« Reply #8 on: December 28, 2016, 10:20:00 AM »
I can vouch for the Tek 2215.  I bought mine new (!) in the early 1980's and it's still going strong.
Bri
Brian Roth Technical Services
Salina Kansas, home of the best vinyl on the planet!
http://www.BrianRoth.com
recordingservicesandsupply.com/
www.qualityrecordpressings.com/
store.acousticsounds.com
