News:
Happy New Year!
feller909
Most reliable/reparable small console
« on: January 10, 2017, 09:44:13 AM »
Hello
I'm looking for a small modular console like Amek BC2-3, Calrec Minimixers, Cadacs, Trident fleximix and similar..
But i'm very scared about maintenance.. I know there are some unavailable parts like "rotator IC" of Cadacs.. A mistic no more available  hybrid amp on Sony mxp 2000 which  can't be replaced with nothing else..
Is there any small modular mixing desk which is fixable for ever?
I really don't want fall in love with a dying mixer
jensenmann
Re: Most reliable/reparable small console
« Reply #1 on: January 10, 2017, 10:32:49 AM »
Soundcraft Deltas don´t have anything special in them. If you recap them and replace the ribbon wire assembly then you should be done for quite some time.... well insert jacks occasionally have problems with their switching contacs, but these are available.
Amek BC3 have a thickfilm (IIRC) assembly for driving outputs. But with some determination this could be replaced with breadboard if necessary.
You could try to find a TAC 16/8/2. They look a bit clumsy and are not modular, so maintaining them is a bit harder. But there´s nothing special inside and if recapped they sound just beautiful.
Of course there are Studers but you pay a lot for them and some parts are unobtainium.
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
dirtyhanfri
« Reply #2 on: January 10, 2017, 11:03:06 AM »
Absolutely Agree on every word, I had (and restored) one of these and (same as TAC Scorpio) it's one of the funniest and fastest console to mix on, ok It's not a SSL, Neve or even Studer, but for daily job it¡s more than enough.
In digital audio era, I think this kind of mixers are the best option for small to mid sized studios. They integrate well with DAW's, recall is a breeze, and you get a summing mixer, faders, a sweet EQ (just for give some touches)....
If I was in the recording business today, I would get one of this small mixers
Working on it...
feller909
« Reply #3 on: January 10, 2017, 12:22:48 PM »
thanks a lot for very fast reply...
I don't like soundcraft mixer's.. I don't use any daw, i need a mixer for my samplers and synths.
I have an Audio Developments AD062 with 8 line mic, 2 aux, stereo master and stereo master compressor,. I need 8 or 12 channels more
I have 4k euro
Are Calrec consoles hard to keep  alive?
pucho812
« Reply #4 on: January 10, 2017, 05:36:18 PM »
or get a toft... They are great bang for buck value and usually don't have  issues.
Every mic has a purpose it might be a door stop or a hammer, but every mic has a purpose.
radardoug
« Reply #5 on: January 10, 2017, 05:45:03 PM »
The Toft is cheap Chinese crap, I definitely wouldn't go there!
« Reply #6 on: January 10, 2017, 09:38:06 PM »
The Minimixer is dead straightforward but done properly and should last a long time.  If one comes up at a good price and the facilities fit you, buy it.  There is no doubt about the quality.
wowi
« Reply #7 on: January 11, 2017, 11:19:06 AM »
Peavey AMR 2400  or 1600. These are build of nothing than standard parts and can be modded if you want.
I am happy with mine and if you need spare parts, i have tons of them :-) I bought a second console (without frame) some years ago.
Wolfgang
pucho812
« Reply #8 on: January 11, 2017, 01:43:50 PM »
China yes, cheap is debatable.  what makes them affordable is the transformer less circuits  and being purely IC based. The input chip is an INA 217 and sounds  fine. The eq  is a trident 80B copy as is the rest of the desk.  About the only non 80B parts are the preamp stage and the inline monitor path. It's ultimately not a bad desk by any means.
radardoug
« Reply #9 on: January 11, 2017, 02:29:27 PM »
Apart from the fact that the pots will all fail in a couple of years. Thats my experience.
mjrippe
« Reply #10 on: January 11, 2017, 03:39:22 PM »
Fleximix is easy to service, with lots of good mods to improve it as well.  You can expand them and choose the modules you want.  Not as cheap as they used to be, but still available.
pucho812
« Reply #11 on: January 11, 2017, 09:00:24 PM »
They don't all fail, but some do go scratchy due to not being  sealed. Easy enough to get around and or swap them.  I've fixed my fair share on that desk, it's not nearly as drastic as you make it.
« Reply #12 on: January 12, 2017, 08:45:17 PM »
The older Soundcraft stuff is super easy to service/maintain/upgrade.  No particularly hard-to-find parts, all pretty much off the shelf.  I have a 2400 with the ground mod and I've had a blast tinkering with it.  The ONLY trick might be finding replacement pots.  Old Piher stuff.  Never had to replace any, though, and mine was built in (I think) 1984.  Just a few considerations: EVERY input and output on that desk is unbalanced, and pin 3 is probably hot.  And you might want to rebuild/recap the power supply immediately.  With the ground mod, a good re-cap and a few IC changes (and the local power supply bypass caps that you should also add if using faster amps) it's quiet as a mouse, and has an interesting character.  There are fairly simple mods for the mic pres as well, though I have to admit I've never used mine so I can't tell you if they're any good.
I also have a friend who's been tinkering with a TAC Scorpion.  Easy to work on, easy-to-find parts.  And these guys make upgraded replacement mic pres for most of the Amek/TAC products:
http://www.audiomaintenance.com/acatalog/aml_electronic_products.html
I've worked on a Toft ATB and wasn't a fan.  There was terrible crosstalk across muted channels.  Also worked on one of John Oram's T-series consoles (while we're talking about Trident people).  Generally liked it; good value, sounded good, but switchgear was AWFUL.  After five years, at least 10 switches needed replacing.  Not that big of a deal in the long run, though.  That desk was eventually replaced by an Audient 4816.
« Last Edit: January 12, 2017, 08:53:48 PM by sircletus »
feller909
« Reply #13 on: January 13, 2017, 01:00:41 AM »
Thanks a lot to all you
I don't like Toft, never readed nothing good about they.. only people with problems. Good soundcraft desks are too big for me, i don't need more than 16ch. I like Fleximix, if i find one i take it.
AML have a lot of parts for small ameks.. i will be safe with a BC2?
But the big quest is:
If an electronic part becomes unavable is there always a work around to make the console working?
electrisizer
« Reply #14 on: January 16, 2017, 04:00:42 AM »
d&r vision - still in production, avaliable as 19", fully modular. clean open sounding.  :)
feller909
« Reply #15 on: Today at 12:44:51 PM »
I found a Glensound.. New topic if someone want see inside the desk
