half_Tube line driver
kambo
CA
have been messing around with one half of 6sn7  as line driver...
very rich second harmonics! thinking of 8ch of it
any comments ::)
edit : final version  C1 1uf : R2 166r to 470r : R3 8K : 600ohm on output TRX secondary
or just copy second half of NYD 6sn7 design...
What load did you use when measuring the harmonics?
The 100K anode resistor is rather high. I suspect this plus the 2K2 cathode resistor means the tube is running at quite a low current. This means its output drive capability will be low and its output impedance relatively high both of which will result in higher levels of distortion.
i was using my lynx 10K in 600r out.
yes, higher the input level is higher the distortion,  but very rich on 2nd harmonics.
i tried 47K and lower/higher cathode resistor, but then i am loosing the 2nd harmonics...
3rd harmonic is jumping in quickly.
its kind a sweet spot at the moment for 2nd harmonics, unless i push it really hard.
(i was thinking this as 8 ch mixers ch input, when i mix 8 channels of stems/groups, none of the audio stems/groups would be that high to push the input to distort too much,
but under 1% THD, mainly 2nd harmonics.... )
frequency response is near flat, except there was a bump at 10hz when i measured with 1uf C1 cap.
then changed C1 to 0.22uf, but didnt measure it yet..
edit: when used the second half of tube, then things are more controllable (similar to NYD's design!)
but i like the idea of only one half for simplicity!
Hey Ian,
i made some changes re your comments! thanks for the input!
although 2k2 is still sounding good with 100K but
8k anode - 470r cathode resistor is bangon  8)
even when driven hard, distortion is still rich 2nd harmonics!
i got about 8db gain... i think i will be fine with it... i can ride the group faders from DAW anyway!
did some audio tests, sounding pretty damn good to me...
i can upload some drum and bass if anyone interested!
cheers
ruffrecords said:
Have you tried with a 600 ohm load on the secondary of the output transformer?
ahhhh, just did that... it increased the THD a lot... from 1% to 8%  :eek:
edit : its reducing output level, so i have to drive it harder = more THD
attached the graph from RMA
i think i got it...
at 0db input, THD is only increasing 0.2 % with readjusted cathode resistor...
cathode resistor now 248 ohm (measured from pot)
edit :  hahah just checked NYD's design he used 250 ohm there with 10K anode... i dont have 10K or
another 2K in my watted resistor collection... i suppose, i will be fine with 10k  - 250r
here some audio files as is
(without 600ohm load)
https://spaces.hightail.com/receive/xPwP6
bpm is 100
