Well maybe not HIFI by todays standards but something like it.
My father wanted a small tube amp, so I built him this.
http://ghr.fi/kuvat/6v6hifiout.png
It has triode connected 6V6 push pull output stages that deliver 2.5W power. 5W might sound like too little power but it seems to be plenty with decent speakers in a 30 square meter/320 square feet room.
Schematic:
http://ghr.fi/kuvat/6v6hifi.pdf
I used output transformers from Toroidy and I'm pleasantly surprised how good they are. Without negative feedback the frequency response is -1dB at 20Hz and -1dB at 20kHz. With 20dB of negative feedback the frequency response is essentially flat from 20Hz to 20kHz. Also there seems to be no issues with stability with 20dB of negative feedback. I put a switch in the back so the negative feedback can be switched on or off. With 20dB negative feedback it needs 2.5V input voltage to get full power and without NFB 250mV.
Guts of the almost complete amplifier
http://ghr.fi/kuvat/6v6hifiin.png
Schematic:
