PaulEngineer
New member
- Joined
- Jan 30, 2017
- Messages
- 1
Hello Have an advantest 3131a with tracking generator.
wenn the tracking generator is used by simply connect a cable between the in and output, no signal is seen at the spectrum analyser.
wenn a 40 MHZ signal from the TG output is send into a 200Mhz Scope then is a 200 mV signal seen on the Scope.
What can be wrong?
A external signal from a signal generator can be seen on the advantest
Does ay have an idea??
What can be wrong?
