80hinhiding
- Joined
- Sep 27, 2016
- Messages
- 97
80hinhiding said:I tried to turn the heater on with a voltage divider last night, using two resistors but it didn't work. I'm guessing it's not that simple.
Voltage dividers work fine as long as you're not drawing any current from them (from the midpoint). If you are, then don't use a voltage divider! This is an important lesson for the future. In some cases where the current draw is low enough, and it's AC current, you can get away with it as long as the midpoint of the divider is bypassed with a suitably sized capacitor. The capacitor will slow down the rate of change, so the voltage will only change a tiny bit with the signal.80hinhiding said:I tried to turn the heater on with a voltage divider last night, using two resistors but it didn't work. I'm guessing it's not that simple. My hope was that I could use the 30V supply I am using for the other test circuits and incorporate a tube for comparison. Put 30V on the plate and 12V on the heater.
The only way I've gotten it to work is by using a specific power supply for the heater.
80hinhiding said:At what point is using a voltage dropping resistor or resistors not a good idea in heating a tube filament?
Adam
80hinhiding said:Well, the heaters looks nice ha but the tube amp I just setup was an epic fail. Signal severely attenuated and filtered.
I wouldn't do that. The reason is the apparent resistance (U/I) of teh heater changes significantly with temperature. When you start the heater is cold and shows about half of its operating resistance; being in series with a resistor (which doesn't change that much), it receives initially a lower voltage than expected, about half, so it takes a long time to rise in temperature. When it has finally reached its operating temperature, it will receive more voltage, in a cumulative way, so the tube may be overheated, which is not good for its life expectancy and its performance. Using dropping resistors on heaters (or incandescent bulbs) is OK when dropping a fraction of the voltage, but not for so much difference.80hinhiding said:I tried to turn the heater on with a voltage divider last night, using two resistors but it didn't work. I'm guessing it's not that simple. My hope was that I could use the 30V supply I am using for the other test circuits and incorporate a tube for comparison. Put 30V on the plate and 12V on the heater.
