Thank you very much for your answer, I will keep you in mind.
I currently work with a D & R Triton and I do not think there is much difference in sound with the Amek, the components and topology of the two are very similar (except automation). The Midas pro5 with sowter 3306 transformers in the inputs of all their channels, their direct outputs and the final stages in the subgroups and master with good transformers, I think if there will be a sound difference. If the sound difference is appreciable and I would not mind if it were something more uncomfortable to work with. Others spoke very well of the Midas pro5 compared to large tables (Neve, MCI), but before getting myself to change all the wiring and finish restoring the mixer wanted to have other opinions.
