It's a detector that cuts the mic "off" (40dB or so) when no artist is in front of it, picture a guitar player and singer, loud amp behind him, when solo starts he goes to the side, the voice mic picks a hell of a lot of the amp. Not with this device, if the guy is in front of the mic singing the mic is open, if he goes away it's closed.
The sensitivity (distance) should be adjusted, phantom powered, little impact on the signal integrity, but as usual, on the stage isn't as critical as in the room.
What is known about something like this? Any project already chewed around?
Here is a comercial example.
http://www.optogate.com/pb07_uk.html
My first approach would be a switch just shunting the mic signal with a low impedance analog switch, if atten isn't enough an extra switch in series should do. This controlled by a tiny µC reading a IR distance sensor, the example mentions a 3 bit code to avoid noises, I guess some "lock-in" should be done to avoid stage lights interference. The trimpot going to an analog input controlling the sensitivity.
I don't know a more generic name either to google it around some more. Any info appreciated.
JS
JS
