Mbira
Transformer lists for projects.
« Reply #20 on: March 30, 2005, 04:59:09 PM »
Got it-I was too lazy to see if those were input or output iron.
Joel
Joel Laviolette
Rattletree   |  https://www.rattletree.com
The Rattletree School of Marimba | https://www.learnmarimba.com
Family Hoof
« Reply #21 on: March 30, 2005, 10:23:34 PM »
Great thread! I love seeing this kind of organization.
Shouldn't we list the turns ratios/secondary loading conditions for each application to assist in wiring and finding even more substitutes?
Since many people have built them, allow me to add...
Neve Class A preamp (1272, 1290, or 1063/73 minus EQ)
mic input ? Secondary loaded with 4.8k (~5k) yields 1200 input when 1:2 (series:series), or 300 input (parallel:series). Originally made by Marinair, part # T1444, or T1454; and later by St. Ives, part # VT22670.
currently available substitutes:
- Carnhill (who purchased St. Ives) VTB9045
- Sowter 9145
- JLM Audio 1:4 ? Two of them as a series:parallel (1:2) or parallel:parallel (1:4) pair.
- Lundahl LL1538 ? Change cap on the secondary from 180pF to 390pF.
- OEP A262A3E ? Wired for series:parallel (1:3.225).
- or use half of 31267 in reverse for 1:2
line input ? Wire series:parallel (4:1) for 10k input. Neve part # 31267. Originally made by Marinair, part # T1422, T1442, or T1452; and later by St. Ives, part # VT22671.
- Carnhill VTB9046
- Sowter 9165
line output - DC gapped, series:series (1:1.5) for 600 ohm output. Neve part # LO1166. Originally made by Marinair, part # ?, and later by St. Ives, part # VT23326(?).
- Carnhill VTB9049 (original replacement), VTB1148 (narrow for rack mounting), or VTB1847 (PCB version w/breakout leads).
- Sowter 8751 (regular size), or 9160 (narrow version for 1RU cases). Both available with leads or solder tabs.
- JLM Audio 1:1:1DC ? Does not require zobel network of 1.5k & .01uF or 600 ohm load on the secondary. Fits in 1RU with at least 38mm internal height.
- Lynx Audio AT600/600-G
Please correct me if this is: a) too detailed, b) has errors, c) missing any info.
Mbira
« Reply #22 on: March 30, 2005, 11:42:03 PM »
Family Hoof,
Thanks for the work.  I have added the info to the first thread.   I was hoping to keep things in this thread to the specific format of my first post.  I think you're right that your suggestestion of listing the turns ratios/secondary loading conditions for each application is a good one-maybe we could start another thread with that info easilly accessable.  I just wanted to have this be one place where you could look at a list and see lots of different iron options...
That said, I don't own this thread or anything.
 :guinness:
Joel
Joel Laviolette
nacho459
« Reply #23 on: March 31, 2005, 06:32:46 AM »
I know I ended up using the same Jensen JT-11-P and JT-10K61-1M transformers on both my LA-2A and G-Pultecs.
asm
« Reply #24 on: March 31, 2005, 09:49:06 PM »
what about the transformer for the MXL 2001 mic with Royer mod (5840 tube).
i know people are using a jensen trans in it, i'll try to find out which model, can you use anything else?
t
...has a 'gold sputtered capsule for vintage sound'...
Chuck78
« Reply #25 on: March 31, 2005, 10:52:19 PM »
Should this end up in the Meta when finished???
The magic is in the music, not the gear. Simple gear is often better.
PRR
clintrubber
« Reply #26 on: April 01, 2005, 03:21:56 AM »
This is a great initiative, thanks all !
Additional suggestions:
W.r.t. the 312, there's at least one API-channel known to man that uses two OEPs (from a DIY-brother from Spain) and it seems to work well (with a 1731-DOA).
Also: Fabio's boards have an OEP-input possibility.
So 312-input: OEP A262A3E and 312-output: OEP A262A2E.
(anyone else having used these two for an API ? I'm going to)
Regards,
  Peter
Mbira
« Reply #27 on: April 01, 2005, 01:11:04 PM »
-edited-
Nacho, are those input or output iron?
Joel Laviolette
Bluzzi
« Reply #28 on: April 01, 2005, 03:54:52 PM »
Also I found a ref. to the Crimson Model CT-400G for the LA2A as an output transformer.
Crimson Audio Transformers
PO Box 244
Cape Girardeau, MO. 63702
(573) 334-6656 or  (800) 434-1107
I found no web site.
Jim
nacho459
« Reply #29 on: April 01, 2005, 04:35:41 PM »
Quote from: "nacho459"
JT-11-P = input
JT-10K61-1M = output
Mbira
« Reply #30 on: April 02, 2005, 12:32:18 AM »
-updated-
Joel Laviolette
Family Hoof
« Reply #31 on: April 02, 2005, 12:50:25 AM »
Mbira,
You should probably just put LO1166 for the N*eve output Marinair #. Sorry for not being clear. Tell the moderators: This must become a meta!
CJ
« Reply #32 on: April 02, 2005, 03:50:31 PM »
I can paste this on the x-former meta once it gets to where ever it is going.
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
Mbira
« Reply #33 on: April 03, 2005, 12:29:48 AM »
-updated-
Joel Laviolette
chrissugar
« Reply #34 on: April 03, 2005, 01:18:28 AM »
CJ , Do you have a recomendation list for the V72, V76.
Also anyone made some experiments with transformers for the REDD47?
chrissugar
Christian Mike Sugar
        CMS-LAB
mike_relay
« Reply #35 on: April 03, 2005, 01:37:15 PM »
Quote from: "asm"
t
I'd be interested in this as well.. Also the transformer for the 603 tube mod...
-mike
dukasound
« Reply #36 on: April 04, 2005, 03:33:07 PM »
Quote from: "mike_relay"
Quote from: "asm"
t
-mike
Mike transformer for Royer mod is Jensen JT-DB-E or JT-DB-EU (where is EU uncased if you have MXL, ADK, Generis with transformer case inside mic).
« Reply #37 on: April 04, 2005, 03:52:39 PM »
Hey, I'd be intereseted in knowing about the V72 and V76 iron too.
Also can someone list mic trafo's.
I need one for my RCA 74b ribbon mic and
or a tube mic like my neumann cm7156? or the graf tube mic?
thanks
TS
I need help with  RCA BA-43/ BA-45. RCA BA-25a, RCA BC3 mic pre's, Gates Level Devil, Federal AM-864u, DIY la2a stuff, Altec 436b
smilinfu
« Reply #38 on: April 04, 2005, 04:18:44 PM »
I am using the LL1578XLs and some LL1636s in my API 312s, but I really have almost no idea what I am doing :shock: .  They are 1:10 instead of the 1:5 a lot of folks use (I have not tried 1:5 so I have no comparison).  This list could get huge, as there are so many options for so many projects.
Anybody have info on the LA-3 ins and outs?
dukasound
« Reply #39 on: April 22, 2005, 09:45:25 AM »
Hi
I can find one UTC HA-108 transformer. I know some specification but for what is this transformer useful. Also where are this transformers embedded.
Duka
Last post August 31, 2005, 04:17:11 AM
by gyraf
Last post March 22, 2019, 07:01:16 AM
by bernatvm
Last post May 26, 2006, 11:57:35 AM
by Siegfried Meier
Last post January 18, 2012, 09:24:49 PM
by Skiroy
