Gibson BR-9 transformers info
beatnik
Italy
I have purchased a very old and rusty Gibson BR-9 guitar amp as a restoration project
Found one secondary of the interstage transformer was shot. I tried taking the transformer apart and finding if the fault was near the end of the winding but no luck.
The amp needs a new interstage transformer but I am not sure of what to replace it with. The original in my amp was an Halldorson, probably custom part number
Mercury Magnetics GA-PI which is a replica of the TF-1001-D Gibson used in other amps, like in some version of the GA-5, which has a similar pi and output stage as the BR-9 but uses EL84s instead of 6V6s
The Mercury recreation is 2.4 : 1 ratio and fits the GA-5 amp that's all i know. Some people on forums reported using it successfully for BR-9 as well but the thing is, after overseas shipping and taxes this little transformer is gonna be very expensive at about $120
Hammond 124 series offers a few cheaper options but they all have different ratios than the Mercury GA-PI.  I am thinking the 3 :1 versions could work as well but I am not sure. Can someone please explain me what should i be looking for ?
http://www.hammondmfg.com/124.htm
One more problem, the speaker was also torn apart and because it is a field coil type i decided to just replace it with a pm and put a choke in the power supply
Do you think I could use an Hammond 155J choke ? It's 15H / 30mA / 1.026KOhm / 400V max
I have attached schematic for this amp
A field coil has high resistance. You need that much resistance.
Two 6V6 will suck at least 60mA. A 30mA choke is not a first choice.
You do not need 15H here.
Personally I would drop a large 2K resistor in there, then adjust for reasonable plate voltages.
are you going to re-sell it or is it going to be a player?
in other words, do you want a museum restore or something that sounds good?
if it is to be a player, punch a hole in the chassis and stick a tube in there to replace the expensive transformer,
if you want to buy an  innerstage  xfmr, look for 20K primary impedance and about a 1:2 ratio, which would mean 80K on P-P grids, and able to take about 15 volts on the primary, Triad HS-35 would work, but is probably expensive,
Fender used an innerstage in there short lived Musicmaster Bass amp, so you might look for one of those,
The original speaker coil measures about 900 Ohm. The choke should match that resistance exactly ?
Current rating around 80mA would be enough ?
Why would you rather use a resistor in place of the coil ? Would this just affect noise performance or also the tone of the amp ?
i am gonna keep this amp so i would definitely prefer tone over authenticity , however the very simple circuit and the unusual interstage transformer seemed kinda different from the other amps i have and this is why i wanted to try preserve the original design as possible
the musicmaster transformer i actually looked into before. classictone makes a replica but i have asked them the specs and the turns ratio is just 1 : 1.35 . do you think this one could actually work ?
but are you also telling me the tone would be better with a tube pi circuit instead of the interstage transformer ?
