abbey road d enfer said:Important caveat: 1000 ohms must be the sum of additional resistor + output impedance of the generator. For example, if the output Z of the generator, teh additional resistor must be 400r.
This already accounted for by measuring the the voltage on either side of the the 1K resistor, The current is V2/Rout. The voltage across the 1K resistor is this current multiplied by 1K. Some simple manipulation yields the formula I gave. The generator impedance will alter the values of V1 and V2 but the formula still holds.
