EDIT: this project turned into a full scale neve console build. yup.Hi folks,
I'm about to start building a Neve inspired monitor mixer to be able to monitor my tape returns.
My Amek BCIII is not in-line and until then, I managed to monitor my 8 track A80 with unused line-in channels. Not the most intuitive monitoring system, and now with that 16 track 2" coming in next week (
), the monitor mixer becomes a necessity.
I'm planning to build a neve 8014ish console in the next couple (dozens) of years, so I figured, let's do that monitor mixer right, so I can fit it in the big one when (if it ever) happens, and also be able to use it as 16 additional inputs at mixdown.
I'm going all passive summing, 70's neve style, with 1272s and everything.
What I need is transformer inputs to unbalance the signal, mute switches, PFL switches, faders (P&G 1520), pan pots with disengage switches, and 2 aux sends with pre fade/post pan switch. I really want the post pan feature for cue purposes, so both the musician and I can listen to the same mix right away. Time saving.
I'm only splitting the signal once, for the aux sends, so I shouldn't need an amplifying stage, should I? Or are the aux pot and the fader going to suck up too much volume?
I came up with this, and would appreciate if anyone could have a look and tell me if i'm missing something. Note that I'm really going for the Neve way of summing, so I really don't want to improve anything over the way they would have done it.
EDIT: Ok, I realize now how naïve I was, thinking I could make this work without gain stages.. I'll come up with something a little more realistic in the next couple of days... I will probably follow the 1883 routing module schematic and stuff a couple of BA183s in there...
