Kid Squid
Re: Neve 80 series Console Build
« Reply #141 on: May 13, 2020, 10:52:14 AM »
Sullins makes male edge connectors.
https://sullinscorp.com/products/?filters=category:312&toggle=in
Bri
Very nice !!! I'll order some up. Thank you for the link Brian.
Oh my! Anybody as experience with them? They could be a real lifesaver..
It is not the same as 4+12, nor is it the same as 4+8, but 4+12 IS the same as 4+8+12....
http://www.facebook.com/LazyLizardLabs
« Reply #142 on: June 23, 2020, 04:00:25 AM »
Amongst other things, I did a quick dry assembling of the frame, just for fun and to see the actual size of it in real life.
I hope it fits in the studio :) 8)
« Reply #143 on: June 23, 2020, 07:35:51 AM »
Haha, I just imagine one second you don't check prior to the build...
That shouldn't be fun
Best
Zam
Kid Squid
« Reply #144 on: June 28, 2020, 09:32:29 AM »
GORGEOUS !!!
« Reply #145 on: September 29, 2020, 12:25:22 PM »
Hi all!
I'm inches away from finishing the wiring of the 13 buss left hand section of the console and I've been doing lots of other stuff, I'll be posting stuff in no particular order!
I had to build the 13 busses for scratch, since it would be too complicated to source the original neve extrusions, and the veroboard strips were a weak link anyway.. I'm getting good at this, building one take me about 50minutes now :)
I'm almost done prewiring the routing module back connectors (they would actually be finished If I had not ran out of soldering wire yesterday night  ::) )
« Reply #146 on: September 29, 2020, 01:27:55 PM »
Here is the (almost finished as well) studer A80 16 track arm remote control.
The empty holes are for red and green status LEDS (ready and record respectively). I'll wire them as soon as the postman brings me my soldering wire  8).
The red pushbuttons are for arming each track individually and the grey one is a Master Repro/Sync switch for switching between the playback head to the sync/record head for overdubbing. I chose to have a master switch feeding relays to switch all the tracks at the same time instead of having one repro/sync switch per track. Individual track switching can always be done at the tape machine if needed! Sasarist help me draw the pcb, I have a couple of them left if anyone's interested ;). I should get the front panels soon! Each track individual remote is wired to the tape machine via its own 6 conductor cable, soon to be installed!
I bought 15 empty 1272 cases to build the line amps. Buses 1>10 will be housed in the center section of the console, while Aux, Cue and solo busses will live in the frame, under the wooden top lid.
Buses 1/2, Aux 1/2, Cue 1/2 and Solo amps will just be regular 1272s, but Buses 3>8 and Buses 9/10 (aka the tape return buses, I didn't know what else to call them) will have modified front and sub-panels to accommodate Mute, solo and "To Buses 1/2" switches
I'll probably keep the additional 31267 transformers required for these modules somewhere in the frame to avoid crowding the line amp enclosures too much...
« Reply #147 on: September 29, 2020, 01:40:56 PM »
I'm also about to start building the monitor / tape transport remote section. I should have the sub-panel this week.
I decided to have a very simple monitor section: an input selector, dim and mute switches and a volume attenuator, alongside a headphone amp and a Studio speaker volume control + follow monitor switch. For I am a man of very simple needs :).
Elma switches and OEP pushbuttons will be used. It will look something like this:
Here are the massive OEP switches for the tape transport remote control:
boji
« Reply #148 on: September 30, 2020, 02:40:49 AM »
https://youtu.be/c6qUw8RhrCc
It's not much, but it means the world to me 🌍😊❤️
Recently passed some audio through first few ch too, so I completely feel ya brother!
Love the frame, metalwork..keep the pictures coming!
« Reply #149 on: October 01, 2020, 09:44:44 AM »
I'd like to discuss the matter of fader wiring again. In the time since I wired the monitor side of the console, I understood that the two leads going in and out of the fader should be two separately screened cables instead of a dual screened cable, to avoid a capacitance effect at lower volumes.
I also read on one of Ian's post that back in the 70's at Neve, there was a convention that it was ok to use dual screened wires for shorter fader connections.
This is how I wired my faders so far, and this was validated by Geoff Tanner, Blake Devitt as well as Ian and Winston over here.
Ever since I did it, I can't seem to understand why one would use the screen to carry the -inf back to B- (0v) and have a separate lead for the chassis connection, instead of the other way around. Can somebody please explain this to me?
« Reply #150 on: October 01, 2020, 10:47:50 AM »
The side cheeks are ready.  ;D
Note how good a laundry drying rack the console makes. Pretty much the only use I can find for it right now  :D
« Reply #151 on: October 01, 2020, 03:34:59 PM »
Probably because there is no need for the chassis connection to return to the sending module. I would think there is only a need to ensure there is a good LOCAL electrical bond between the metal body of the fader and the actual chassis.
« Reply #152 on: October 17, 2020, 10:25:27 AM »
Looks nice!!
Do you have a source for the panel mounting solution that neve (and many use)
The fast screw hookup.
Regards
Tommy
« Reply #153 on: October 17, 2020, 02:30:27 PM »
Looks nice!!
Regards
Tommy
I think Dan Alexander has some, but I didn't use them, I just used isep bits with m3 strips!
« Reply #154 on: October 20, 2020, 04:17:29 PM »
Some time ago I finished wiring the routing modules connectors! Quite a few wires!
Note the use of 2,5mm2 wire for the connector to B- copper bar connection. Neve used 1,5mm2 for this, but I went with a bigger gauge, following Blake Devitt's advice. Every millimeter counts to beat cross talk, and thus improve clarity, stereo image and so on...
Fitting the knee covers (3mm powder-coated steel, very heavy  :o)
Last post November 24, 2005, 01:27:14 PM
by Bookkeeper
Last post April 23, 2006, 10:12:03 AM
by Rob Flinn
Last post October 10, 2006, 07:17:37 PM
by Rob Flinn
Last post September 26, 2010, 01:51:30 PM
by SIXTYNINER
