Re: !!! Neve Console Build !!!
« Reply #40 on: May 13, 2019, 07:21:55 AM »
Where are you getting the metal work and faceplates done? They look nice.
I'm wondering about the same thing?
« Reply #41 on: May 13, 2019, 04:21:13 PM »
I made them.
« Reply #42 on: May 14, 2019, 04:17:59 AM »
I made them.
How? Are they powder coated or just painted? How did you do the print?
« Reply #43 on: May 14, 2019, 06:01:41 AM »
How? Are they powder coated or just painted? How did you do the print?5
Powder coating and N fronts are not good idea.We use som hi quality industrial paints.Print is UV print
« Reply #44 on: May 14, 2019, 11:21:13 AM »
Excuse my ignorance but what do you mean by "N fronts"?
« Reply #45 on: May 14, 2019, 01:11:58 PM »
Neve mate.
cheers
« Reply #46 on: May 15, 2019, 04:12:02 AM »
Thanks for the info.
How come?
r2d2
« Reply #47 on: May 15, 2019, 07:02:31 AM »
Only "as well" ….
anybody made some test ( also "virtual" ) about " THD"  and signal to noise ratio
for a classic 16 or 24 ch  to  L-R master bus ?
cheers
PS :
just to avoid unpleasant sound surprises….
(after so lot of work…. and money too..)
« Last Edit: May 25, 2019, 01:22:04 PM by r2d2 »
..... Cracking D.Vader Firewall ...  II-)
« Reply #48 on: May 16, 2019, 04:38:51 AM »
How come?
First is the colour problem, powder coating has very limited palette to chose from.Second is overall look , satin gray blue paint look much better to me.I spend a enormous amount of time to find right one , and at the end it turn out, that Mercedes satin paint was the best.
« Reply #49 on: June 05, 2019, 06:24:17 PM »
Only "as well" ….
cheers
PS :
Well we're doing everything by the Great Neve Book, so I guess THD and SNR should be pretty good :) Not trying to reinvent the wheel, here !
« Reply #50 on: June 05, 2019, 06:39:45 PM »
Sorry everyone, it's been a while since I posted anything, been awfully busy at the studio! As Sasa showed you, there's been quite a bit of progress on the tape return modules side... well actually, they're DONE! I just got them today! And they look and feel stellar! As you can see, they're just missing their 31267 input transformers, which they'll be getting very soon!
I'm also in the process of finishing the CAD files for the bucket panels of the console, they'll be in production before the end of the week! This is getting real, I'm so excited!
r2d2
« Reply #51 on: June 06, 2019, 06:02:56 AM »
The project is so Extremely "porn"…..   :o
if it sound as the original (...as expected) , is 10X  Extremely "porn"  :o
cheers
« Reply #52 on: June 09, 2019, 04:57:28 AM »
cheers
Actually , I test modules and they sound beyond my expectations.My biggest concern were our custom inductors , but it tourn out that they  "affect" sound in a same way as geniune, one which are wound on smaler core.
Anthon
« Reply #53 on: June 09, 2019, 08:12:45 AM »
Building a console of this size is quite an undertaking! But if you actually manage to do it, then you can call yourself a guru of DIY audio  ;D
Keep up the good work!
I also have plans to build a console eventually, but something more simple, like API 1604.
« Reply #54 on: June 22, 2019, 10:46:55 AM »
Hey all!
Last week, I got the first bucket panels from the laser shop, so I did a first assembly test to see how everything fits. And it all works perfectly!!
Couldn't be happier with the results, I'm ordering the rest of the panels this week-end!! Then they need to be tapped and countersunk. I'm also about to order the ISEP hardware for making sure all the modules will slide in flawlessly.
When I get all this, I can start assembling and wiring the frame up  8) 8) 8)
mjrippe
« Reply #55 on: June 22, 2019, 11:16:02 AM »
That is dead sexy!  And I like your taste in furniture as well  ;D
« Reply #56 on: June 22, 2019, 11:17:56 AM »
Haha thank you! Well, the house was quite messy, but thanks for the compliment anyway  ;D
« Reply #57 on: June 22, 2019, 07:56:06 PM »
Hello
Impressive.
look great !
Any automation planed ? let me know...
Best
Zam
Rob Flinn
« Reply #58 on: June 26, 2019, 06:19:53 PM »
I'm interested to know about the output transformers it appears you have wound.    I am looking at the split bobbin, is one side secondary & the other primary ?  Looking at CJ's winding docs for the 1166 it appears that there are 2 primary layers & 3 secondaries.
See here
https://img1.wsimg.com/blobby/go/0e07cc59-2f5a-481f-967d-12c7363b86fa/downloads/1ctuvlm4f_626108.png?ver=1559636350707
regards Rob
« Reply #59 on: June 27, 2019, 03:40:44 AM »
See here
Hi Robb, Those are not LO1166, they are T1310 inductors. This inductor was used at neve to load the BA183/283 cards when no balanced output was required. A traditionnal neve switching unit would have 1 BA183 before the fader,  loaded with such an inductor, and another BA183 before the buss sends, loaded with an LO1166 to use as a direct output.
Those modules in the pictures are just  tape return switching units for the right side of the console, so they don't need direct ouptuts, hence the two T1310 inductors. As a matter of fact, the left side, 8 buss 4aux switching units we're about to build won't have LO1166 for direct ouput either, as I don't have the need for them. I'd much rather use a buss.
On a side note,  you can see on the pictures  that the modules are not fitted with an input transformer yet. I'll be using OEP 31267 transformers.
Last post November 24, 2005, 01:27:14 PM
by Bookkeeper
Last post April 23, 2006, 10:12:03 AM
by Rob Flinn
Last post October 10, 2006, 07:17:37 PM
by Rob Flinn
Last post September 26, 2010, 01:51:30 PM
by SIXTYNINER
