midwayfair
Kids, don't try to remove screws from a capsule without covering it.
I was replacing the capsule in my 251 build, and after removing it, I started taking off the wire leads so it would fit in the capsule box. The screwdriver slipped and boink right into the diaphragm.
Funny thing is, it doesn't look punctured. I think it might still work (and certainly if I use it one-sided), but it'll probably never sound the same and the Campbell capsule is now staying in the 251 for sure.
So before I go popping this into a test microphone -- how bad is it? Is it fixable without reskinning the capsule? Does this short the membrane to the backplate if it's "stuck" and is there a way to get it unstuck?
