Hey guys. I'm new here. I see that you all are very helpful. I'm currently having a problem with my boost converter design. The requirements are to step up 8-12V to 30V at 1 Amp. I have calculated the values and simulated it and it works. 220uH inductor, irlz44n mosfet, 1n5819 5A schottky, 10uF cap, 30 Ohm 50W load, (3 10Ohms in series). The pwm controller is an attiny45 which supplies 100khz signal to the FET. The feedback loop is a 390k and 33k voltage divider across the load. The problem I am having is that the prototype boosts to well over 50V with no load attached but as soon as I attache the load the output voltage drops to 0.
Your help will greatly be appreciated.
