Rca OP-6 attenuator values
burdoto
St Paul, MN
Howdy,
I've searched around everywhere I can think of and can't figure out the set up for the OP-6 gain control. I'm wondering what the total value of the switch is and how the resistor network to ground is set up. Does anyone know? I may not be able to find info cause no one knows, in which case I can use the BA-2 first stage arrangement.
Dan
I can supply these built on a repurposed Daven attenuator for $300.  They lack the 'off/mute disconnect' switch, otherwise exact fit and operation.  Can probably be done on a modern Elma for $200.
