I have been toying with the idea of adding dual concentric pots to the Foldback and Echo sends on my Neve 1883 routingmodules.
The original modules share one pot for both sends so you can not set each gain induvidually which would be better in my opinion.
But would adding an extra four 10k pots to the circuit be problem?
The signal to the pot is taken pre/post the fader so comes directly from the output of either the first or the second BA238AM cards output.
In the larger modules with eight sends (and four 10k pots) its wired the same so i guess it should not be a problem to add them.
But if i wanted to do the same on the larger module and add four 10k pots for a total of 8 x 10k, could that be a problem?
I have included the 1883 schematic for reference, the lager routingmodules like the 1943 is exactly the same but have 8 group outputs and a total of 8 sends for Foldback and Echo.
