I have a pair of these racked in the early naughts by Boutique Audio & Design.
I have not used them in a while and upon testing noticed that both channels are exhibiting a skewed frequency response.
Here's a slow RMS metered white noise through one of the channels:
http://agatha-christie-fanclub.tumblr.com/post/158710104561
the other channel exhibits the same response (or similar enough not to see it very differently on the spectrum meter)
I'm at a loss to figure out why this is happening.
I thought it might have been the output transformers though disconnecting and coming directly from the card to the meter ins and bypassing the transformers yeilds a similar skewed response.
Something seems to be acting as a high pass filter on both the individual channels.
Where da low end go?
A secondary seemingly unrelated problem is that a single channel has its 18k high cut malfunctioning - once the switch is engages at that point the signal drops out completely or near completely (sending a lot more gain seems to pass low level high frequencies) the 910 Ohm resistors after the switch seem to measure close as do all the others (in circuit) so I'm guessing it's the Wasp switch point that's most probably the culprit
For reference these modules are the V03 35102 with single NE55 op amp in the mic pre section
The card with the Mic / Line transformers has D253 Issue B *AND* Issue F printed on the circuit board
The card with the Wasp switches has D258 Issue D
P.S. There does not seem to be any extra electronics added for driving the electronics to the output as it seems many folks have installed for what it seems like is for headroom reasons
If I had the extra cash I would hire a tech but It's not possible right now for me hence joining up here in the hopes of some kind guidance.
Sincerely,
Geoffrey
Sincerely,
Geoffrey
