What is the actual available hight inside a typical 2U rack mounting enclosure? I have designed a 3 inch tall (76.2mm)PCB and it is not clear to me if this will fit vertically in a 2U rack (88.9mm). I have looked at lots of datasheets and they all give the front panel height but none tell you the internal height. My board is about a half inch shorter than the rack height so I have about a quarter inch play top and bottom. Is this enough?
ian
ian
