I have a 12V lithium battery bank capable of handling over 300A surge for 30 seconds (according to mfg spec).
Using an inverter that's capable of 2000W continuous and 4000W surge, I'm trying to power a small window AC unit.
The continuous power consumption on the AC unit is 600W, but the momentary surge when the compressor kicks on is somewhere closer to 1200-1400W. It's enough to drop the voltage from the battery to the inverter by 2 volts for about 2 seconds which shuts down the inverter output until the voltage recovers.
I have 10 * 56,000uF capacitors I was thinking of putting in parallel across the inverter input terminals, hoping that might help decouple the momentary voltage drop. Since I already have the capacitors on hand, it would be much cheaper than buying another lithium battery bank.
Any thoughts or better ideas?
