samgraysound
I've been working on racking a pair of PM1000 master modules and something weird is going on.
I used the Monitor Amp section as the 1st stage and the main line amp as the 2nd stage. So wiring a input xfrmr to C15 then taking the output at c20 and connecting it to the level control R9 and then on through line amp, ouput xfrmr and out. I also added a gain control to the 1st stage of the amp, by replacing trimmer R40 with a 100k log pot. I'm using input and output transformers from the original PM1000
Its powered by a power supply kit providing +44 and +48. The power xfrmr is in a seperate chassis, and the PS PCB is in the chassis with the audio boards.
I'm getting a horrible oscillation when I turn up the module. The frequency varies widely as I move the controls from independent clicks to high squealing. That seemed like parasitic oscillation to me. I've replaced all the signal runs with shielded cable. I've tried reversing the leads on the transformers. It does pass signal along with the oscillation but only at the gain level where the oscillation starts.
I'm missing something. Maybe I put an electrolytic cap in backwards? Ideas?
Sam
Sam
