I've got a circuit with LM339 driving several LEDs. LEDs are powered from a constant current source. In this configuration, the meter works in bar mode. Is there any way to make it display in dot mode? Or do I have to remove constant current source and feed the LEDs through ballast resistors (this way I can use pull-ups for dot mode, need to check this though)?
