Collins Radio Co. 356A-1 preamp gain mod and rackup
« on: April 04, 2017, 01:28:59 PM »
Here's a process log on a recent Collins 356A-1 preamp restoration, mod, and rack-up.  These were for a client, he had them already and sent them to me.  He wanted all the modern conveniences, along with padding for line use, so the input pad is -20/30/40.  These are fixed gain as stock, I sorted out a feedback path mod to increase gain without giving up the tertiary winding path entirely; there’s another thread that addresses that.  Max output level is high enough to justify an output attenuator, so it’s on this one.  The output load switch is kinda pointless using a modern CAPI/Hairball 600 ohm T, as it’s minimum loading is 1K, unlike a correct T which goes open at the off position, so the load resistor is a 2K2 for a minimum load of 710R.  I found a real Collins logo for the front panel.  PSU's are all DC and off-the-shelf.  Linear B+ and filament, switching 48V.
Click this link for larger pic
PSU.  Required iso diodes to avoid latch-up through shared A-/B-.  Added second DC output jack for use with theoretical additional preamp rack.
« Last Edit: April 04, 2017, 02:08:14 PM by emrr »
musika
Re: Collins Radio Co. 356A-1 preamp gain mod and rackup
« Reply #1 on: April 04, 2017, 01:33:24 PM »
Very nice!!!
mjrippe
« Reply #2 on: April 04, 2017, 06:34:35 PM »
Beautiful work, as usual, Doug!
My3gger
« Reply #3 on: April 06, 2017, 04:24:34 PM »
Very nice and it is always interesting to get well informed about American approach to pro audio. Why is input cathode cap C202 of so low value? They could easily pick foil type instead what looks lytic. C 203 seems coupling cap, i'm not sure if C204 makes filter with R205. Interesting circuit which could help making layouts because HT is below. Maybe CJ's joke about German audio and amphetamine paranoia wasn't just joke :) Wish we had modules from them or any other good European for cheap, American are not well known at all. Those who know them like their sound a lot, like that "sound glow" from BA-2, very exciting.
I'm just finishing modifications with very similar controls as yours here. Added IT primary switching for ribbons and typical 150-200 ohms mics, might not be needed today with active ribbons. I'm still not sure if better new models have ~200 ohms impedance and higher gain than passive. No one replied. Output control will be 1k pot, works well with NYD schematic having resistors before it.
« Last Edit: April 06, 2017, 04:29:36 PM by My3gger »
« Reply #4 on: April 06, 2017, 09:34:06 PM »
Look again.  That's not the cathode cap.
But if it was, it'd be for treble boost.
C204/R205 is addressed in the link about the gain mod.
« Reply #5 on: April 08, 2017, 01:39:55 PM »
Would you be willing to post a diagram of the gain mod? It's not 100% clear from the description in the thread linked.  thanks
skippo
« Reply #6 on: January 31, 2019, 03:58:28 AM »
Hi Doug,
Really beautiful work on this, I've been looking at some of your other posts too on these preamps. I going to be racking up some 356-As soon and I was wondering if you had a link to the power supply you used?
Also the plug in connectors on the modules look new, do you have a source for those?
Thanks for your help!
best
Asher
« Reply #7 on: January 31, 2019, 11:31:34 AM »
International Power for B+ and filament, both from Mouser.  The 48V is a Meanwell, I've mentioned it in a thread about phantom somewhere here.  I put another RC filter on it's output.
https://www.mouser.com/ProductDetail/Mean-Well/RS-25-48/?qs=sGAEpiMZZMuEhFEw3BeJbc0V%2fVK7k4iujqnPf2qQDII%3d
The connectors are intermittently available from several different manufacturers, it's different every time I look.  If they aren't at Mouser today, they will be in 6 months.  Or from Allied.  Waldom sometimes.
http://www.mouser.com/catalog/catalogusd/645/2570.pdf
skippo
« Reply #8 on: January 31, 2019, 03:46:59 PM »
Thanks!!
« Reply #9 on: June 08, 2020, 12:43:45 AM »
What is the purpose of the "out" terminals of the phantom switch being strapped together.  It also looks like there's a resistor and cap between the two switch terminals as well.  This confuses me a bit.  Also,  how and where did you implement the isolation diodes for the power supply lines?
 thanks,
Ry
« Reply #10 on: June 08, 2020, 01:01:10 AM »
Look at the Jensen phantom schematic AS016.  Ground bus to drain the local cap.
The resistor is a load for the switcher when no phantom is active.  The cap is local filtering, there's also a small resistance between the switcher and the local filter.
The iso diodes were not added at the time of the pics, they are in series with B+ and filament if I recall correctly.  Seems confusing now, possible it's only the B+, unless I modified the filament supply for higher voltage, which I may have.
« Reply #11 on: June 08, 2020, 03:17:21 AM »
Thanks Doug,
I guess I found it confusing because it looks like a nSPDT switch is drawn in the Jensen schematic and the switch in your pictures look like an SPST, so did I miss that?  If one just used an SPST switch for the +48 VDC line, then the caps would not drain, correct?
 So do you have an additional resistor in your design that's not in the Jensen schematic? Is R1 in your case a part of a separate RC filter at the Input XLR connecter on the back of the unit as seen in the photos or is it the resistor that is the load at switcher?
I think I'm close to wrapping my head around this.
thanks,
Ry
« Reply #12 on: June 08, 2020, 09:41:25 AM »
I think you’re looking at the load switch.
