Can we call it "ParaGraphic" ?
r2d2
A-rea 51
.....typical while looking for a "thing" .....for shure you found something "else" ......  ;D
and this "else" is a stuff like this :
http://www.preservationsound.com/wp-content/uploads/2013/08/ADR_E950_eq.jpg
if i'm not wrong some other manufacturer made similar stuff ....
it will be a today  Diy project ?
(really "captured"  :p by those unconventional faders !)
r.
r.
It's actually full parametric....
A few decades ago I played around with the concept of mounting two mono frequency slide pots horizontally, with the boost/cut  pot mounted between the two sliders vertically. A rotary pot at the slider of the boost cut pot could tweak the Q.  This carried the "graphic" concept of WYSIWYG even further. Center frequency was varied by sliding the boost/cut pot left/right. I was going to display the Q graphically with a knob that had wings that expanded out or retracted to indicate wider/narrower bandwidth.
This would have been "cute" with overlapping frequency bands..I never did figure out an effective front faceplate to cover up the works.. perhaps some overlapping dark panels.
Just another example of design mental masturbation...  (we don't have to build every single idea we have.).  :p
