Tube preamp front panel design
Yes, the low shelf is, indeed, a low shelf with three positions (flat, -3db at 150Hz, -6db at 150Hz). It's not a HP filter.
I am using large toggle switches. As this is a point-to-point design, the extra size helps me fit all the components in.
Nice design! Elegantly done, I'm a sucker for  good mockup. No obvious alignment issues or typos or anything that I can see (on a phone screen at least).
Will you be screen printing to get the different colours on the panel?
What does "off" position of the gain switch really mean?
The beige and black borders shouldn't be placed at the edge of the panel to my taste, but that's just me.
I prefer that you have "Gain" under the control.
I like the font you've used. I would use a different font for your name/brand.
For the shelf control, you need to identify what each switch position does.
