I've got an H3000 on the bench. At first it had some intermittent noise issues on the left channel. That was fixed with re-seating the opamps on that channel. I noticed it had a level mismatch between the channels (not much...0.6dB, just enough to annoy me).
To isolate that issue, I did a reset of the unit, created a patch with the noise generator sent to both outputs, and turned the input all the way off. The levels were the same on both outputs so I ruled the output side out as an issue. Unfortunately the copy of the service manual I have is missing part of the input section. I watched the output with a spectrum analyzer in the DAW and also a scope and set the offset and distortion pots. The left channel is lower in level no matter what I do. It's also noisier than the right channel. I'm wondering if the Murata filter on the left channel is a bit off.
LCD Backlight is kinda dim. The +5v is good, so I'm thinking dropping R23 on the front panel PCB should do the trick (currently 5r6, I'll try 3-4r or so and see how that goes).
I checked through all of the suggested updates in the service manual. They're all implemented so nothing to do there.
I plan on replacing the PSU electrolytics, upgrading the ROMs to "kitchen sink," and replace the battery/RAM module.
Anyone know where to get case screws for this thing? Any other things I should look at?
