dissonantdissident
- Joined
- Sep 7, 2014
- Messages
- 78
Hey there,
I've been trying to track down the cause of pops in one of my vp25 channels, and haven't been able to figure it out. Here are the symptoms:
Unlike my other three CAPI VP25 channels, this one had audible pop when engaging/disengaging the mute and phase switches. Has since I got done with assembly. Also, there is noise that is audible whenever you tough the input cable coming into the channel. I've switched it to numerous 500 rack positions, just to make sure it is the unit (not raack connector), which it definitely has to be, after trying different spots.
I've reflowed solder joints and replaced the switches with new ones, but the problem has remained.Everything else works about the channel, Passes signal, phantom, etc. Just every time you hit one of those switches there is a pop and touching the xlr in makes crackles, but in every position in the 500 rack.
I'm not really sure where to look and it bugs me that this one channel isn't working right. Any tips or direction appreciated.
