fatty
Member
say i've got a mic input transformer with a high step up ratio, say about 1:10. if i was to mic up , say, a snare drum, couldn't i just plug the mic into the transformer and then straight into a compressor and use the make up gain on the compressor if i need a bit more signal?
is there any impedance issues or anything else i haven't taken into consideration?
will the signal level still be far too low, even after the step up?
