My vintage scope broke down (probably PSU caps are dead), but I need measure the power output of my DIY half power Bassman (with 6v6).
I had an idea, of taking a multimeter, setting it on AC peak volt metering, and increasing the 1kHz output into a 8ohm 100W resistor, until the voltage stops to increase. When the distortion starts to kick in, you shouldn't see increase in peak voltage, right?
Then I could measure RMS value, and calculate the power as usual.
I guess this would only work if the clipping is symmetrical...
Or any other approaches that work reasonably good? (accuracy of -+1W is good enough).
