JamieOxford
Member
- Joined
- May 7, 2017
- Messages
- 24
I'm currently wiring a TT patchbay and need to connect unbalanced inserts from a mixer to it.
I've been using the Rane site for info on wiring other cables but I couldn't find a solution on there for this.
The patchbay will be half-normalled to my audio interface which has balanced I/O.
I found the below diagram on another thread. Is this the correct/best way to wire it to the patchbay? ie, TT Send wired with the ring tied to ground, and TT Return ungrounded?
I want to avoid full balancing or anything too costly.
Any help is appreciated!
